I have an original Fit 2, which I love. I’ve designed several watch faces I use every day.
However, Samsung recently required an Android app update if I wanted to allow my phone to continue to connect to my Fit. So I did. Then the app said I had to factory reset my phone. I did, grudgingly, even though I knew I would lose all my watch faces.
Then I set up the watch (WiFi, Debugging, etc.), fired up my original Gear Watch Designer (v1.3), and it said my certificates had expired. It let me update my author’s cert, but when I connected my watch (successfully) and tried to update the designer cert, it found my device, but then went away into never-never land and never came back. The screen remained blank, no “Congratulations” message. I tried this several times.
So, I tried updated to the new watch design studio (v2). Found out it doesn’t support my watch. Thanks, Samsung.
I tried using v1.6.2 (the latest that Samsung says is compatible with my Fit 2). It supposedly updated both certs successfully, but fails about 60% into the install with a data dump indicating that some certificate (it didn’t specify which) was expired.
So I tried v1.5.0 and v 1.5.3. They, too, let me connect and update both certs and build my watch faces. But when I try to run any of them on the device (including the samples that come with the SDK) they fail and about 60% with the message “Existing tpk is not valid for this device.” Yeah, the existing tpk it just build for my device that it found and connected to.
It almost seems like Samsung has updated the firmware on my watch to render it incompatible with the existing watch design SDKs, meaning if I want my own watch faces, I’ll have buy a new watch.
I’ve tried all the above on two different Windows machines (XP and 10). Same behavior.
I tried running Tizen Studio on my Ubuntu 20.04 box and was unable to update my certs on it, as well. If anyone has any experience on building Fit 2 watch faces under Studio on Linux, please chime in!
Any ideas what’s going on, or how I can get my watch faces back on my Fit 2?
Thanks.
