Hi, Guys
This time I’m making a clock with a white background.
I added a Complication there, but it wasn’t visible so I changed the Complication color to black.
However, in AOD mode, there is a problem where the complication is not visible due to the black background.
So, when in AOD state, I want the Complication color to be white.
As long as the tag expressions feature is not available in the color input, it is very difficult to change the complication color based on normal or aod conditions. Hopefully the next version will have a tag like [IS_AOD], so to change the color just add ([IS_AOD]>0?#FFFFFF:#000000)
I did not use the trademark for any commercial purposes.
This is a developer forum, so my posts may be uncomfortable to read.
I will contact you separately from the person who used my personal creations.
I will resolve it personally.
