I need help with the steps complication
So, i made a watch face and i don’t know what im doing wrong but whenever I set the complication to steps in the watch, it shows the text “steps” underneath it despite having selected only to show “icon” and “text”. I did not turn on “title” but it shows in the watchface.
Also any reason why the steps icon and text "steps "won’t show in the watch face studio?
Delete the ones you don’t use/want.
I think it will do the trick.
As above but also check the Default Data setting for that comp .
Hi dulapalliashish1,
If you don’t want the user to be able change your complication type, you can try selecting “Fixed” from “COMPLICATION SETTINGS”.
Regards,
Imrul Anwar
