Starting in WFS version 1.8.7 and now in 1.8.10 images are not saving correctly. When saving images used for publishing the font used is replaced with a system font. This happens randomly and images must be taken again. After two or three try’s it will make the correct image.
I’m not sure how to explain it but hopefully these pictures will explain it better. In this example I am using Roboto-Medium font for all text. As you can see all the text has been changed from the snapshot image to the saved directory. As you can see the gray text time has been saved two different ways. Not sure why.
Some times when we have some fonts large on these Platforms Issues arrise . It may be they are only happy being a certain pixle size . Give the Chrs a nice big bounding Box .
