Hi everyone, I have a problem, plus a difficulty on galaxy watch studio, I can’t angle the lines, unlike other components whose angle can be moved, I can’t find the small reference square on this one.
I need this to put the lines in the corner areas of the clock, Thanks ![]()
I am not sure what line are you trying to rotate, but if you insert an rectangle index element (small line)then you can set in properties how many such index lines you want around the dial and they will be all placed automatically turned in their positions.
