Is there a way to check a log or something? Is there any limitation?
I’m tired… my project does not save… everytime i close the WST all gets lost, no image, no complication, no fonts… And when i check the files inside the .aab it does not have any of the images or font files…
Hello,
Every time you close a project or quit the Watch Face Studio toll, a popup window came and asked to save your project or not. If you don’t get this pop up please share the information:
Watch Face Studio version
A video of when you close any project or quit the Watch Face Studio tool and don’t get any popup
In addition to what Boshra said.
Usually when I see this issue it is because your location in the project build menu is not what you think it is, check that in your build settings.
Are you opening a .wfs project with an older version of Watch Face Studio. That can cause issues.
You may want to rename to save an old log they can get very long but they are generated in this folder
Windows : C:\Users{User}\AppData\Roaming\watchfacestudio\dump\main.log
macOS : /Users/User Name/Library/Application Support/watchfacestudio/dump/main
