Please, can you add/replace user-friendly tag HR_MEASURED_TIME? Example - MM, or HH:MM. Thx.
Firstly, a big THANK YOU to SDP for coming up with WFS and improving upon it and offering it to partners and enthusiasts free of charge.
Like the GWS, the WFS is an awesome tool for non-IT literateâs to design WF without coding. I trust over time the WFS will be a much better tool.
Thank you
We could not reproduce the problem. Could you share the log file in your PC for further analysis?
You can find main.log from
C:\Users{user name}\AppData\Roaming\watchfacestudio\dump\ in PC
/Users/{user name}/Library/Application Support/honeyface/dump/ in Mac
Thank you!
A nice innovation is this wave effect when you tap on a shortcut.
What is less nice is that today I updated a Watch Face with the new WatchFaceStudio and the hands have been jumping since then.
(Only if AOD is deactivated).
Hello,
I canât build a watch face on WFS 1.0.11 anymore. It gives the below error.
Although I didnât choose the oppo watch devices the watch face I made with the watch face studio 1.0.11 was rejected by Google due to a Heart Rate problem on the square watch. I canât update it because I canât build it.
Hi SDP team, need help.
I managed to âbuildâ an app on WFS 1.0.11 by creating a new Keystore folder. Looks like this will be the new protocol where I will have to create a new Keystore folder for each App.
That aside, I now have another issue. Cant âRun on deviceâ. My Watch4 had some issues two days ago but it has been recovered after a Hard-reset (It may be related).
- Connect via Wi-Fi
- Failed to detect Watch4 although appropriate âDeveloper Optionsâ steps were complied with.
- Conect via BlueTooth
- One requirement which is to âenable Debugging over Bluetoothâ, via âAdvance Settingâ on âWear companion appâ was not possible in my case. Because,
a) The âGalaxy Wearableâ app on my device does not have âAdvance Settingâ feature
b) My deviceâs Setting (S10+) only has âDebugging over USBâ
Appreciate if you could shed some light on this.
Thank you.
There is a small error in the manual. Advanced settings must be selected and debugging turned on on your watch, not your phone.
It was already written about it here in the forum.
Dear all
Today, we released [hotfix v1.0.12].
It fixed only the issue about complicationâs layouts @amoledwatchfaces reported. Thank you @amoledwatchfaces again.
We are also investigating other issues reported in this thread, but havenât figured it out yet.
It is recommended to uninstall the previous installed WFS programs before installing new version 1.0.12 and to change the location of workspace or keystore.
If you still have difficulties, please register it as a new topic.
Thank you
Hi
We have already released hotfix v1.0.12
We recommend to uninstall the previous installed WFS programs before installing new version 1.0.12 and install again. If you still have difficulties, please register it as new topic.
Sorry for inconvenience.
Great news !
Big thanks to all people from WFS team for this hotfix update
Hi, thank you for the update.
About this Keystore, I read in another topic (posted two months ago), but I could not comprehend it. Since WFS 1.0.0 I have build two Aps by âsheer luck/trial-by-errorâ in sorting the Keystore . But really could you please help break it down?
BUILD
- Location: Is this to locate where to save our new .abb / .apk?
- Version Name vs. Version Code: I know we can enter anything, but what is it intended for?
- Keystore Path: Locate where our GWS Keystore is or create a new folder?
- Key alias : Please, what is this?
NEW KEYSTORE
- Keystore Path : Is it the same as above?
- Key alias : ?
Your feedbacks will be greatly appreciated.
Thank you
Thank you Ron for the explanation here: WFS Build Keys and Passwords? - #16 by r.liechty_SDP
Hope I got it right
I must admit that I did not follow this advice.
I installed a new version overwriting the old application. Everything works fine. I have no problems with the keys. WFS read them correctly.
It was. Java crashed when I updated windows.
Uninstall Java.
Restart the computer.
Install Java
WFS doesnât really use Java it uses Java Script when it builds.
Try moving your keystore to a different folder.
Ron
Samsung Developer Relations
Thank you for the feedback.
The error surfaces only when building one particular app. However, for the benefit of doubt I did take your advice, but the error persisted.
Thank you Ron,
I have tried three different folders for Keystore, but error persisted.
This happens on only one specific âconvertedâ app. WFS works fine with other app builds. My suspicion is there something within this app is not setup correctly. Iâve audited each element but could not detect the culprit
Hello everyone, issue resolved.
Whilst I still did not detect the source, it somehow resolved by going back to GWS, replaced all shortcut tags with only what WFS can recognize. I then open new project in WFS, imported the TPK, reassign the shortcutâs tag expression. Thatâs all.
I can build and run on device without any errors.
Thank you.
