EDIT: I have used Ranged Value layout 5 and it pulls in watch battery icon, % and bar fine, however when I switch to phone battery complication in customisation menu it only shows the copy ‘Phone Battery: 71%’, no icon or bar… any ideas?
Hi. You should use Text + Icon + Progress Bar layout as this app provides min, max, value, text, icon.
Thanks for the swift reply guys, however it isn’t working for phone battery not sure if it is a bug or something I am doing, see below WFS, watch battery chosen on watch customisation, then phone battery:
Which layouts do you have enabled for this complication in WFS?
Hi @jsmith88 you not using that layout. You giving the complication the abilities to choose any of the enabled layout in wfs.
I explained in your other thread click “x” only leave the layout u want to use
Or rearranged the order
You need to remove or play with other layouts. WFS is using really weird conditions in RANGED_VALUE complication and sometimes wrong layout is prioritized. You should still be able to see progress bar however. Make sure to move RANGED_VALUE above short text too.
Amazing thanks mate, will gove that a go (i didnt know about this so explains alot and would have saved me many hours if i knew from the start!!)
Awsome will give this a go and shout if any furthe issues, this forum is awesome go team!
Thank you , My phone % got it working now on my watch face. By installing Phone Battery complication on my phone and watch at the same time.
Really do appreciated it.
Thnx again
The helper app can’t work with the battery conditional line?
Hi. No, conditional line is for watch battery SourceType.
