Hello I have a problem with the Galaxy S21 Emulator Skins the mask is diplay bad, have you got this problem ?
I have not seen anyone report this on this discussion board did you follow all the instructions as written HERE?
If you did then please open a support request and explain the issue there.
Thanks for reporting this.
Ron
Samsung Developer Relations
Hello,
Yes I follow all the instructions. After some days of use I understand that this problem happens when I’m using the emulator of android studio but not when I’m using the external Android Emulator.
Hello, I have the same issue with Android Studio
I have the same issue when I use Android Studio to Emulator Galaxy S21 skins. And I followed all the instructions above 2 times. The first attempt didn’t work, but the second attempt was surprisingly successful.
Thanks a lot,
Tin Thanh
I had the same problem. I renamed the extension for fore_port image from .png to .webp and resized it to match the device. After that it worked for me. It is possible that the renaming is enough.
