I have downloaded and added a device skin from Samsung for my Galaxy Note 9, but for some reason when I run the virtual device in my Android Studio setup it shows a white bar across the device screen. I’ve tried both hardware and software emulated performance with no luck. Has anyone else come across this and know how to fix it? All my settings are set up to the specs outline on the Samsung Developer site.
Hi,
First of all, thanks for using our service!
May we know what API or system image you are using in Android Studio?
The skins should be stable on API 28 (Android Pie) and below. Moreover, download and try to use the skins again in https://developer.samsung.com/galaxy-emulator-skin/overview.html.
Regards,
Galaxy Emulator Skin team
Thanks. I am using API 29 as that’s what my current OS is. Is this not supported?
Here’s my specs
CPU/ABI: Google APIs Intel Atom (x86)
Path: C:\Users\admin\.android\avd\Samsung_Galazy_Note_9_API_29.avd
Target: google_apis [Google APIs] (API level 29)
Skin: 1440x2960
SD Card: 2 GB
fastboot.chosenSnapshotFile:
runtime.network.speed: full
hw.accelerometer: yes
hw.device.name: Samsung Galazy Note 9
hw.lcd.width: 1440
hw.initialOrientation: Portrait
image.androidVersion.api: 29
tag.id: google_apis
hw.mainKeys: no
hw.camera.front: emulated
avd.ini.displayname: Samsung Galazy Note 9 API 29
hw.gpu.mode: auto
hw.ramSize: 1536
PlayStore.enabled: false
fastboot.forceColdBoot: no
hw.cpu.ncore: 8
hw.keyboard: yes
hw.sensors.proximity: yes
hw.dPad: no
hw.lcd.height: 2960
vm.heapSize: 256
skin.dynamic: yes
hw.device.manufacturer: User
hw.gps: yes
skin.path.backup: _no_skin
hw.audioInput: yes
image.sysdir.1: system-images\android-29\google_apis\x86\
showDeviceFrame: no
hw.camera.back: virtualscene
AvdId: Samsung_Galazy_Note_9_API_29
hw.lcd.density: 480
hw.arc: false
hw.device.hash2: MD5:392e084813a05089592220caae61637d
fastboot.forceChosenSnapshotBoot: no
fastboot.forceFastBoot: yes
hw.trackBall: no
hw.battery: yes
hw.sdCard: yes
tag.display: Google APIs
runtime.network.latency: none
disk.dataPartition.size: 18G
hw.sensors.orientation: yes
avd.ini.encoding: UTF-8
hw.gpu.enabled: yes
Hi,
Try downloading it again and it should now work with API 29.
Let me know if there’s still any issues.
-Galaxy Emulator Skin
Perfect! All working now. Thanks
