We are developing a webapp where each customer has it’s own subfolder working as seperate PWAs. One of them has a german umlaut (ä,ö,ü) in it’s name where the installed PWA can’t be started.
When pressing the install button and acknowledging the install prompt the PWA seems to install with no errors. After the installation has finished the notification pops up and the icon of the PWA is shown in the installed apps, but not in the statusbar of the Samsung Internet browser.
When trying to start the PWA from the launcher you can very briefly see a black closing screen and afterwards it’s shown in the taskmanager, but also completely black.
After reloading the page the install button shows up again so you can “install” the pwa mutliple times.
To get it installing properly it’s enough to just change the folders name (no change to the serviceworker, manifest or any other component) and also the other PWAs with no umlaut in the path work fine.
We also couldn’t reproduce this issue with other browsers like chrome or on other systems like windows.
Same with the Beta. We have tested with several phones like Galaxy S8, A5 (2017) and 21 FE.
To demonstrate the issue I set up two very simple PWAs with two different paths (one installing fine, one not) and took a video of the behaviour. I used Chrome Remote Debugger, so don’t be irritated by the IP.
As you can see, the first one named “PWA ok” with path “/test/” works fine, the second “PWA fail” with path “/töst/” doesn’t. Only real difference is this one letter in the path.
Both work fine using Chrome.
