QB55R (Smart Signage)
Hi All,
I hope the post is in the right section. Otherwise tell me where to move it.
I have a smart signage monitor with tizen 4.0 on board and I would like to install apps to make it usable with live streaming services or install a browser that has full and not limited functionality like the one currently on board. I tried to access the monitor through Tizen Studio but it does not allow me access on port 26101. Can I install the apps once I can access the monitor? If so, how can I solve the login problem? Can I install the apps directly from a connected USB device?
Thanks in advance
I was hoping someone could help you. All I can suggest is you go the The Smart TV seller store 1:1 support and ask for help there.
Ron
Samsung Developer Program
