Hi, I’m using the Samsung Privileged Health SDK and am currently trying to get the PPG Green, IR and Red data. However, I’m a bit confused about the values I got. I can’t seem to find any meaningful interpretation of the values.
The SDK docs only tell me that those are the raw values of each PPG. But what is the meaning of those value? What is the value range?
Thank you.
Hi aditydcp,
As you are using Samsung Privileged Health SDK, you can directly communicate with the Samsung Health team officially for any kind of support.
Here is the link for communication: https://developer.samsung.com/dev-support
Hope this will solve your problem.
Thanks.
Ok, I’ll try to do that.
Thanks for the reply!
