Hi everyone,I noticed that when pressing volume down or up and opening the new audio panel,it seems to lag a little bit when being opened. After i enabled in developer settings that stuff which is gpu rendered should flash green,almost every UI element was being gpu rendered but volume panel wasn’t. Device: Galaxy S10 8/128gb EU. SM-G973F/DS.
I think you are asking this as a developer if so you will probably need to open as support request and give full information.
If you are asking as an end user that is just using Developer Options this is not the correct forum for end product bug reports, questions or concerns. You should post at https://www.samsung.com -> Click on Explore Tab -> Click on Community.
Because end user questions disrupt developer discussion if it isn’t a developer related question this thread will be removed at some point.
Ron
Samsung Developer Program
