Samsung Dex: S21Ultra keeps waking up when using external keyboard to type
Hi All,
Just like to share the issue that I am facing when using Samsung Dex on my S21 Ultra:
When using Samsung Dex, my S21Ultra will constantly screen wakes up by itself whenever I use my external keyboard to type on web browser app or and other apps that requires typing. I’m using an USB dongle for my external keyboard and mouse. I have tried testing the same setup on the following devices, S20Ultra, Note20Ultra and Note20 5G (All devices are on the latest software) and nor of them face the screen waking issue when typing. I have even go to an extend to factory reset my S21Ultra and it did not solve it. I strongly believe it is a software issue that needs Samsung Mobile Software Team to look into and fix it.
Device Information:
Model: SM-G998B/DS
One UI version: 3.1
Android : 11
Android security patch level: 1 May 2021
I hope there will be a hotfix software update soon to remedy the problem ASAP as I am using Samsung Dex on my S21Ultra for my work. Do drop me a reply if if you manage to find a solution to the problem
Thank you
Regard
Ken
Hi Ken,
Please report your issue via Samsung Members app and include system bug report while submitting error report. Respective team will investigate your issue.
Thank you.
I don’t use this feature but it seems to me that the issue is the display being active as the cpu/mobo are quit active when using Dex.
Work around is to manually dim down the display when using Dex which will cut power consumption.
this happens to me too using 2.4G keyboard. the current solution for me is to click on “use as touchpad” and dim the screen. But I am using a usb hub with usb c charger port. power is not a problem but I think the batterie could take dmg when screen is always on without needing.
Are you using the Microsoft SwiftKey keyboard on the Galaxy device? Of so you need to switch to another keyboard like the Samsung keyboard to prevent this from happening. This also occurs to me but only when using the SwiftKey keyboard.
Hi , i think you just need to disable the folow pointer to phone screen.
I know this is an old thread, but for others stumbling across it…
The solution is to go to Settings → Samsung DeX → Keyboard and be sure that TV/Monitor is selected for on-screen keyboard…
Screenshot_20240921_001024_Samsung DeX home
This was the solution for me. Thanks a bunch! :hugs:
