Samsung TV (no developer mode)
According to Samsung’s service, [TV] UN40J5200 or 40" Full HD Flat Smart TV J5200 Series 5
UN40J5200AF has no Developer mode? Is that possible? Is it possible to test a SMART-TV app on a TV without Developer Mode?
As far as I know all Smart TV’s have a See Tizen Studio Developer Mode end user support may not want to tell you how to do it.
Legacy Smart TV’s prior to 2015 have a separate method. I you have a legacy Smart TV go to this link and then scroll down all the way to the end for running on 2011, 2013 and 2014 models
Ron
Samsung Developer Program
Ok, I managed to activate the developer mode but it takes an apache website to host the SMART-TV app. The TV will connect to the ip address of the site to import the SMART-TV app. Is it possible to use Visual Studio 2017, compile, packaging applications for upload the SMART-TV app and deploy it to the Apache website in ‘User App Sync Server (with TV) tab’ from the ‘Samsung SMART TV tab’ ? It would seem that this is not possible. Is that possible?
I don’t know much about SmartTV development but you should be able to use Visual Studio with the Tizen SDK to develop Smart TV web apps. You should check out the information on the Smart TV developers portal I’m sure you would understand much better than I can.
Ron
