i’ve tried different second hands on my watch design and they show fine on the preview but once uploaded to my watch do not see them. any ideas?
Hello, sorry I do not have idea what might be wrong, but just to make clear if anybody else wanted help, what program/watch are you using? You posted this question in two different sections.
Only the obvious one that you added the second hand to the AoD and not the Normal watch face. It won’t show in Normal and it won’t show in AoD because it isn’t allowed in AoD.
Ron
Samsung Developer Relations
Thank you. I’m using Galaxy Watch Studio. But that worked. Sorry for posting in 2 places. I’m new at this.
It is kind of common in GWS because it isn’t always noticeable which “work” window you are in Normal or AoD. the button to change is in the upper right hand corner and you can tell because if it is the AoD work window the OPR shows but in the normal work window it does not.
Enjoy Designing
Ron
Thanks. I’ve seen watch faces where I, as a user, can change the color of the digital clock digits in normal runtime but don’t see that it a design option in GWS?
I believe they use clear bit map fonts and change the colors below it with Tap action. If you search the forum you should find the solution.
Ron
This deserves to be put in FAQ section.
Check the last section of this guide:
