With the Gear Fit Pro2 some standard Watch Faces are installed. The can also by styled (change color as an example). How to do that in GWD 1.6.2 for my own Watch Faces?
TIA,
Arjan
TIA,
Arjan
If you go to the Galaxy Watch Designer Tutorial you will find there a many ways to customize a personal watch design for your Fit Pro2 using GWD 1.6.2.
Some customizing features available on pre-installed watch faces are not available to GWD or Tizen Developers as there is no public API for them. But generally you can do things with buttons and tags.
Ron
Samsung Developer Program
