Hi looking for some guidance on using custom tags like KM/Miles/Kcal for progress 0-100% on custom image rotation.
For example im using steps and battery with no issues like below for my custom progress images.
Rotation field I set to 180
Tag = [SC_PER]*(-180/100)
Tag = -[BATT_PER]*(-180/100)
So for the formulas below how would I make this rotate based on % like im doing for batt/steps please.
So my images are 180 and need to rotate -180, I have tried adding *(180/100) at the end does not work.
KM - [SC] STEPS | ((([SC]*0.745)-([SC]*0.745)%1000)/1000% 100 ).((([SC]*0.745)%1000-([SC]*0.745)%100)/100)((([SC]*0.745)%100-([SC]*0.745)%10)/10)
MILES - (([SC]*0.00475)*1%1>=0.5?([SC]*0.000475)+0.1-([SC]*0.00475)*1%1/10:([SC]*0.000475)-([SC]*0.00475)*1%1/10)
Hello,
sorry, but I do not understand what are you trying to do. Why would you expect to have different % of the distance or miles if you calculate them from steps?
the formula is easy: [tag curent value]/[tag goal]*rotation range in degrees
P.S.: [SC_PER]=[SC]/step goal*100
Thanks for the reply and yes Peter of course you are correct I guess I was trying to show a percentage bar with a range of say 0 to 7.45 KM different to say 1 - 10000 steps but itβs all coming from the limitation of having to use SC.
and Sinjae thank you for the new simple expressions I will give that a go on the next face.
