"Tag" for Watch Face Studio to display kilometers and calories?
@asadulhuq . Your formula above is a bit Longer than it needs be . I will check it but I assume it gives two Decimal places . This one does as well .
km (round(([SC])*0.0762)/100)
I shall check this formula. Thanks.
Yes Do . I have to keep it Simple otherwise my Brain says I don’t Understand . WFS has a number formatting Tag but I prefer this one as I can understand it better thus remembering it .
While we are on the subject I should make you aware of the Steps Goal Tags . They show the Goal Setting and a percentage of you Goal achieved .
[SC_GOAL]
[SC_PER]
This formula works. 1 digit is placed after the decimal point when last digit is zero (last zero is not displayed). Thanks.
0 step - 0 km
7 - 0.01
20 - 0.02
33-0.03
99-0.08
112-0.09
125-0.1
138-0.11
1000-0.76
1306-1
5000-3.81
10000-7.62
50000-38.1
@asadulhuq . If you are talking about this formula I am surprised I get two Decimal .
km (round(([SC])*0.077)/100)
You will not get double zeros after the decimal pont. And also no decimal point. If the 2nd digit after the dp is 0 then the last zero is not shown .Please see my previous reply.
Your formula is simple and hence better than the long formula.
Thanks.
One comparison
Your: 1306 steps -1 km
Long: 1313 steps - 1.00 km
OK Sorry . I understand . Yes we have no Z for the Formula . We can get the Double Zero and Leading Zeros with the WFS number Formatting . Would you like me to show you a test of that .
Please show. I am afraid that the leading zeros formatting will make the formula long! Thanks.
No the formatting Utility is quite neat . Just counter intuitive .
@asadulhuq . See that you play with the number of Zeros Before and After the Decimal point . I am very fond of the battery read out being three Numerals so the composition is preserved . Especially if it is curved .
(numberFormat("00.00",(round(([SC])*0.077)/100))) KM
Thanks. I shall check it soon and let you know the result.
The above formula works well. However, I would like to omit the 1st zero. I like 1.50 Km more than 01.50 Km. Thanks a lot - I learned a lot from you.
Asad_test_2024_Jul_03FTempKm3_20240703_21091578
Screenshot_20240703_231652_weather
This forum is a lot about People who publish their Faces ( Try To ) . But there must be room for those starting out on their Journey . You must look at the various mathematical styles and see which suits you best . Some use Bots to generate Formulas . For me they are incredibly Counterintuitive an Teach me noting about Maths as they are so complex .
Nice Easy reader BTW .
