Theme rejection (how to fix?)
Hi team, any idea of how can i fix this errors?
#1 – You can use images for the Radio Button, but make sure the actual image layer on the 96x96 image is centered at 72x72 otherwise there’s a bug on the Fold on the Side Button screen where the images will be cut off on the left.
#2 – The Month Name on the Year screen should be the Calendar Cirlce color – the current day should also have this colored circle around it and you should see this in the tool. Looks like your circle color is black on a black background.
#3 – This I do not understand and have received it about 10 times… in a ticket response they told me to make sure that on both regular and cover Lock Screens, ensure both Light and Dark Clock screens have the same screen attributes (Clock Font Effect). So if you have a Stroke on the Light make sure you have Stroke on the Dark. I’ve never had one approved after this rejection (reviews are taking so long) so don’t know if this is an actual fix, but it’s a BS rejection. It occurs because if you don’t specify a Clock font from the dropdown, the Preview image will never match the actual Phone, because they both use different default fonts.
Hope this helps :blush:
Thank you for info, yes there are a lot of bugs and I still don’t understand after 8 years as a developer why the Samsung team can’t fix this problems which comes every year with the new version of Android.
It’s really annoying to see the same problems for all designers. There are maybe thousands of themes rejected for the same reason, so the problem is not with the design but with the Theme Studio version.
As expected they are completely clueless when it comes to themes… their fix for the Lock screen preview rejection did not work. They now say they are working on it but it’s going to take time!
And its not even a valid rejection, they do not comprehend logic.
They haven’t fixed any of the many bugs I’ve reported in the past two months.
Edited: It would be nice to have competent developers help fix the tool, and actually work with us to help solve the problems :sob:
