Is there a way to create a “button” to turn on WATER LOCK from the watch face? Save a step from going into the pull down settings panel.
Thanks
Thanks
Hi @pwbrama,
Unfortunately, there’s no such an option in GWS to directly turn on the WATER LOCK from the watch face. You can just open the Settings and then you have to manually complete it.
Azad
Hi Azad,
i need to have the option to activate and deactivate the waterLock in my App. Im looking for a script with this kind of implementation., but not i have not found too much… even the sugestions from ChatGTP do not work. Do you have any idea how to program this function in third party Wear OS APP´s
