Hello,
I’m trying to debug a crash issue that appeared with the latest Android 11 update on Samsung devices using the Remote Test Lab service, but when I use any device with Android 11, I’m never able to get the adb connection working.
In Android 11 (using various Remote Test Lab devices), I do
- Test/Remote Debug Bridge
- adb connect localhost:xxxxx
failed to connect to localhost:xxxxx (device shows as offline) - I never get a prompt on the device to “trust” the connection
When I use a Android 9 or 10 Remote Test Lab device with the same steps, everything works (and I get the prompt on the device, which I confirm).
Is there a problem with Android 11 and the Remote Debug Bridge?
adb
Android Debug Bridge version 1.0.41
Version 30.0.5-6877874
Thanks,
Iowa
