Using Conditional Lines With GIF Animation
Hey ALL!
I have a couple of questions:
  1. I’ve been working on a Flip Watch Face compiling each digit (9/0, 0/1, 1/2, you get the idea). I guess I’m not understanding how to use either the trigger for animated media, or making the objects “flip” to the next digit in Conditional Lines. Can I get a better understanding of either?
    Or, can Tag Expressions be used instead?
OC-FLIP-00-001
  1. I also tried using the Tap method to change media to “erase” a cover to reveal more events, and digital complications. The top media has a digital clock on it, and I want to “erase” all of the objects on the top including the running digital clock. The Tap feature will only do this for regular images and not running time, or animated media. Or is there a way to do this?
OC_383_WEYLAND YUTANI CORP_001_20240601_18322673
OC_383_WEYLAND YUTANI CORP_001_20240601_18340507
Thanks
Hello,
Could you please share what type of issues you are facing?
Yes. Thanks for speaking with me about this.
The Animation problem is that I was trying to use conditional lines for each second that passes, or use the activation tools when using media. I want to make a full face flip watch, but I’m not sure how to set it up in either conditional lines, or the Trigger.
The other problem is using Current time n top of a button, then when you tap to see other information the button and the time on top of that disappears when you tap the image that is the button but still see the actual digital time under the button after the top and time are erased.
I’ve been trying to find a way for a long time but haven’t been able to find anyone.
S2+
([SEC] ==0)+([SEC] ==10)+([SEC] ==20)+([SEC] ==30)+([SEC] ==40)+([SEC] ==50)? 0 : -100
([SEC] ==1)+([SEC] ==11)+([SEC] ==21)+([SEC] ==31)+([SEC] ==41)+([SEC] ==51)? 0 : -100
([SEC] ==2)+([SEC] ==12)+([SEC] ==22)+([SEC] ==32)+([SEC] ==42)+([SEC] ==52)? 0 : -100
([SEC] ==3)+([SEC] ==13)+([SEC] ==23)+([SEC] ==33)+([SEC] ==43)+([SEC] ==53)? 0 : -100
([SEC] ==4)+([SEC] ==14)+([SEC] ==24)+([SEC] ==34)+([SEC] ==44)+([SEC] ==54)? 0 : -100
([SEC] ==5)+([SEC] ==15)+([SEC] ==25)+([SEC] ==35)+([SEC] ==45)+([SEC] ==55)? 0 : -100
([SEC] ==6)+([SEC] ==16)+([SEC] ==26)+([SEC] ==36)+([SEC] ==46)+([SEC] ==56)? 0 : -100
([SEC] ==7)+([SEC] ==17)+([SEC] ==27)+([SEC] ==37)+([SEC] ==47)+([SEC] ==57)? 0 : -100
([SEC] ==8)+([SEC] ==18)+([SEC] ==28)+([SEC] ==38)+([SEC] ==48)+([SEC] ==58)? 0 : -100
([SEC] ==9)+([SEC] ==19)+([SEC] ==29)+([SEC] ==39)+([SEC] ==49)+([SEC] ==59)? 0 : -100
S1
([SEC] ==0)+([SEC] ==1)+([SEC] ==2)+([SEC] ==3)+([SEC] ==4)+([SEC] ==5)+([SEC] ==6)+([SEC] ==7)+([SEC] ==8)+([SEC] ==9)? 0 : -100
([SEC] ==10)+([SEC] ==11)+([SEC] ==12)+([SEC] ==13)+([SEC] ==14)+([SEC] ==15)+([SEC] ==16)+([SEC] ==17)+([SEC] ==18)+([SEC] ==19)? 0 : -100
([SEC] ==20)+([SEC] ==21)+([SEC] ==22)+([SEC] ==23)+([SEC] ==24)+([SEC] ==25)+([SEC] ==26)+([SEC] ==27)+([SEC] ==28)+([SEC] ==29)? 0 : -100
([SEC] ==30)+([SEC] ==31)+([SEC] ==32)+([SEC] ==33)+([SEC] ==34)+([SEC] ==35)+([SEC] ==36)+([SEC] ==37)+([SEC] ==38)+([SEC] ==39)? 0 : -100
([SEC] ==40)+([SEC] ==41)+([SEC] ==42)+([SEC] ==43)+([SEC] ==44)+([SEC] ==45)+([SEC] ==46)+([SEC] ==47)+([SEC] ==48)+([SEC] ==49)? 0 : -100
([SEC] ==50)+([SEC] ==51)+([SEC] ==52)+([SEC] ==53)+([SEC] ==54)+([SEC] ==55)+([SEC] ==56)+([SEC] ==57)+([SEC] ==58)+([SEC] ==59)? 0 : -100
([SEC] ==0)? 0 : -100
([SEC] ==10)? 0 : -100
([SEC] ==20)? 0 : -100
([SEC] ==30)? 0 : -100
([SEC] ==40)? 0 : -100
M2+
([MIN] ==0)+([MIN] ==10)+([MIN] ==20)+([MIN] ==30)+([MIN] ==40)+([MIN] ==50)? 0 : -100
([MIN] ==1)+([MIN] ==11)+([MIN] ==21)+([MIN] ==31)+([MIN] ==41)+([MIN] ==51)? 0 : -100
([MIN] ==2)+([MIN] ==12)+([MIN] ==22)+([MIN] ==32)+([MIN] ==42)+([MIN] ==52)? 0 : -100
([MIN] ==3)+([MIN] ==13)+([MIN] ==23)+([MIN] ==33)+([MIN] ==43)+([MIN] ==53)? 0 : -100
([MIN] ==4)+([MIN] ==14)+([MIN] ==24)+([MIN] ==34)+([MIN] ==44)+([MIN] ==54)? 0 : -100
([MIN] ==5)+([MIN] ==15)+([MIN] ==25)+([MIN] ==35)+([MIN] ==45)+([MIN] ==55)? 0 : -100
([MIN] ==6)+([MIN] ==16)+([MIN] ==26)+([MIN] ==36)+([MIN] ==46)+([MIN] ==56)? 0 : -100
([MIN] ==7)+([MIN] ==17)+([MIN] ==27)+([MIN] ==37)+([MIN] ==47)+([MIN] ==57)? 0 : -100
([MIN] ==8)+([MIN] ==18)+([MIN] ==28)+([MIN] ==38)+([MIN] ==48)+([MIN] ==58)? 0 : -100
([MIN] ==9)+([MIN] ==19)+([MIN] ==29)+([MIN] ==39)+([MIN] ==49)+([MIN] ==59)? 0 : -100
M1
([MIN] ==0)+([MIN] ==1)+([MIN] ==2)+([MIN] ==3)+([MIN] ==4)+([MIN] ==5)+([MIN] ==6)+([MIN] ==7)+([MIN] ==8)+([MIN] ==9)? 0 : -100
([MIN] ==10)+([MIN] ==11)+([MIN] ==12)+([MIN] ==13)+([MIN] ==14)+([MIN] ==15)+([MIN] ==16)+([MIN] ==17)+([MIN] ==18)+([MIN] ==19)? 0 : -100
([MIN] ==20)+([MIN] ==21)+([MIN] ==22)+([MIN] ==23)+([MIN] ==24)+([MIN] ==25)+([MIN] ==26)+([MIN] ==27)+([MIN] ==28)+([MIN] ==29)? 0 : -100
([MIN] ==30)+([MIN] ==31)+([MIN] ==32)+([MIN] ==33)+([MIN] ==34)+([MIN] ==35)+([MIN] ==36)+([MIN] ==37)+([MIN] ==38)+([MIN] ==39)? 0 : -100
([MIN] ==40)+([MIN] ==41)+([MIN] ==42)+([MIN] ==43)+([MIN] ==44)+([MIN] ==45)+([MIN] ==46)+([MIN] ==47)+([MIN] ==48)+([MIN] ==49)? 0 : -100
([MIN] ==50)+([MIN] ==51)+([MIN] ==52)+([MIN] ==53)+([MIN] ==54)+([MIN] ==55)+([MIN] ==56)+([MIN] ==57)+([MIN] ==58)+([MIN] ==59)? 0 : -100
([MIN] ==0)? 0 : -100
([MIN] ==10)? 0 : -100
([MIN] ==20)? 0 : -100
([MIN] ==30)? 0 : -100
([MIN] ==40)? 0 : -100
H2+
([HOUR_1_12] ==0)+([HOUR_1_12] ==10)+([HOUR_1_12] ==20)+([HOUR_1_12] ==30)+([HOUR_1_12] ==40)+([HOUR_1_12] ==50)? 0 : -100
([HOUR_1_12] ==1)+([HOUR_1_12] ==11)+([HOUR_1_12] ==21)+([HOUR_1_12] ==31)+([HOUR_1_12] ==41)+([HOUR_1_12] ==51)? 0 : -100
([HOUR_1_12] ==2)+([HOUR_1_12] ==12)+([HOUR_1_12] ==22)+([HOUR_1_12] ==32)+([HOUR_1_12] ==42)+([HOUR_1_12] ==52)? 0 : -100
([HOUR_1_12] ==3)+([HOUR_1_12] ==13)+([HOUR_1_12] ==23)+([HOUR_1_12] ==33)+([HOUR_1_12] ==43)+([HOUR_1_12] ==53)? 0 : -100
([HOUR_1_12] ==4)+([HOUR_1_12] ==14)+([HOUR_1_12] ==24)+([HOUR_1_12] ==34)+([HOUR_1_12] ==44)+([HOUR_1_12] ==54)? 0 : -100
([HOUR_1_12] ==5)+([HOUR_1_12] ==15)+([HOUR_1_12] ==25)+([HOUR_1_12] ==35)+([HOUR_1_12] ==45)+([HOUR_1_12] ==55)? 0 : -100
([HOUR_1_12] ==6)+([HOUR_1_12] ==16)+([HOUR_1_12] ==26)+([HOUR_1_12] ==36)+([HOUR_1_12] ==46)+([HOUR_1_12] ==56)? 0 : -100
([HOUR_1_12] ==7)+([HOUR_1_12] ==17)+([HOUR_1_12] ==27)+([HOUR_1_12] ==37)+([HOUR_1_12] ==47)+([HOUR_1_12] ==57)? 0 : -100
([HOUR_1_12] ==8)+([HOUR_1_12] ==18)+([HOUR_1_12] ==28)+([HOUR_1_12] ==38)+([HOUR_1_12] ==48)+([HOUR_1_12] ==58)? 0 : -100
([HOUR_1_12] ==9)+([HOUR_1_12] ==19)+([HOUR_1_12] ==29)+([HOUR_1_12] ==39)+([HOUR_1_12] ==49)+([HOUR_1_12] ==59)? 0 : -100
H1
([HOUR_1_12] ==0)+([HOUR_1_12] ==1)+([HOUR_1_12] ==2)+([HOUR_1_12] ==3)+([HOUR_1_12] ==4)+([HOUR_1_12] ==5)+([HOUR_1_12] ==6)+([HOUR_1_12] ==7)+([HOUR_1_12] ==8)+([HOUR_1_12] ==9)? 0 : -100
([HOUR_1_12] ==10)+([HOUR_1_12] ==11)+([HOUR_1_12] ==12)+([HOUR_1_12] ==13)+([HOUR_1_12] ==14)+([HOUR_1_12] ==15)+([HOUR_1_12] ==16)+([HOUR_1_12] ==17)+([HOUR_1_12] ==18)+([HOUR_1_12] ==19)? 0 : -100
([HOUR_1_12] ==0)? 0 : -100
([HOUR_1_12] ==10)? 0 : -100
H2+
([HOUR_0_23] ==0)+([HOUR_0_23] ==10)+([HOUR_0_23] ==20)+([HOUR_0_23] ==30)+([HOUR_0_23] ==40)+([HOUR_0_23] ==50)? 0 : -100
([HOUR_0_23] ==1)+([HOUR_0_23] ==11)+([HOUR_0_23] ==21)+([HOUR_0_23] ==31)+([HOUR_0_23] ==41)+([HOUR_0_23] ==51)? 0 : -100
([HOUR_0_23] ==2)+([HOUR_0_23] ==12)+([HOUR_0_23] ==22)+([HOUR_0_23] ==32)+([HOUR_0_23] ==42)+([HOUR_0_23] ==52)? 0 : -100
([HOUR_0_23] ==3)+([HOUR_0_23] ==13)+([HOUR_0_23] ==23)+([HOUR_0_23] ==33)+([HOUR_0_23] ==43)+([HOUR_0_23] ==53)? 0 : -100
([HOUR_0_23] ==4)+([HOUR_0_23] ==14)+([HOUR_0_23] ==24)+([HOUR_0_23] ==34)+([HOUR_0_23] ==44)+([HOUR_0_23] ==54)? 0 : -100
([HOUR_0_23] ==5)+([HOUR_0_23] ==15)+([HOUR_0_23] ==25)+([HOUR_0_23] ==35)+([HOUR_0_23] ==45)+([HOUR_0_23] ==55)? 0 : -100
([HOUR_0_23] ==6)+([HOUR_0_23] ==16)+([HOUR_0_23] ==26)+([HOUR_0_23] ==36)+([HOUR_0_23] ==46)+([HOUR_0_23] ==56)? 0 : -100
([HOUR_0_23] ==7)+([HOUR_0_23] ==17)+([HOUR_0_23] ==27)+([HOUR_0_23] ==37)+([HOUR_0_23] ==47)+([HOUR_0_23] ==57)? 0 : -100
([HOUR_0_23] ==8)+([HOUR_0_23] ==18)+([HOUR_0_23] ==28)+([HOUR_0_23] ==38)+([HOUR_0_23] ==48)+([HOUR_0_23] ==58)? 0 : -100
([HOUR_0_23] ==9)+([HOUR_0_23] ==19)+([HOUR_0_23] ==29)+([HOUR_0_23] ==39)+([HOUR_0_23] ==49)+([HOUR_0_23] ==59)? 0 : -100
H1
([HOUR_0_23] ==0)+([HOUR_0_23] ==1)+([HOUR_0_23] ==2)+([HOUR_0_23] ==3)+([HOUR_0_23] ==4)+([HOUR_0_23] ==5)+([HOUR_0_23] ==6)+([HOUR_0_23] ==7)+([HOUR_0_23] ==8)+([HOUR_0_23] ==9)? 0 : -100
([HOUR_0_23] ==10)+([HOUR_0_23] ==11)+([HOUR_0_23] ==12)+([HOUR_0_23] ==13)+([HOUR_0_23] ==14)+([HOUR_0_23] ==15)+([HOUR_0_23] ==16)+([HOUR_0_23] ==17)+([HOUR_0_23] ==18)+([HOUR_0_23] ==19)? 0 : -100
([HOUR_0_23] ==20)+([HOUR_0_23] ==21)+([HOUR_0_23] ==22)+([HOUR_0_23] ==23)? 0 : -100
([HOUR_0_23] ==0)? 0 : -100
([HOUR_0_23] ==10)? 0 : -100
([HOUR_0_23] ==20)? 0 : -100
12H
([IS_24H]<0)+([IS_24H]>0)?-100:0
24H
([IS_24H]<1)+([IS_24H]>1)?-100:0
