Is there a way to see which settings were made in the past on the Samsung device or Samsung Internet browser? In other words, can I get a list of the settings I’ve previously adjusted?
Thank you for participating in the Samsung Developer Forum. However, this is not the correct forum for end product bug reports, questions or concerns. This forum is for 3rd party developer issues.
If it was possible it would be in the Settings > Apps >{APPNAME} for each app. I did not find anything that does this.
I would recommend you use the Samsung Members App for feedback
or
go to https://www.samsung.com and depending on your location
either → Click on Explore Tab → Click on Community
or
Scroll all the way down to the bottom of the page and under support is a link to the community
Because end user questions disrupt developer discussion this thread will be removed soon.
Ron
Samsung Developer Community
