Weather forecast tags
When you write your formula it is working on WFS simulator?
or are you see your formula instead of the data number?
Now I see that it has to be like this:
(forecastDays(1,"COND_DAY"))
And you get:
Hello @masterboyhr,
This is my first message on the forum. I am looking for the exact same feature you described: (forecastDays(1, "TEM_LOW"))° / (forecastDays(1, "TEM_HIGH"))°.
The issue is that WFS displays the tag texts instead of the actual temperatures, and the same happens on the watch.
I tried using the tags in several components, but the result is always the same. Could you tell me what I might be doing wrong?
Thank you very much by advance !
Don’t use ‘smart’ quotes.
I honestly cannot say why it’s not working for you.
I don’t see any error.
When I enter the formula - it works.
Do you have the latest version of WFS installed?
version 1.7.13
@masterboyhr You didn’t actually enter the same formula! You used the correct quotes, whereas @Demokrit didn’t.
Smart quotes really should be turned off in a software forum.
I must say I’m confused by quotes, cannot say I understand the difference.
I was warned by Peter and Russell about the text formatting here so now I mark formulas as “blockquote”.
I don’t trully understand the difference between smart, straight, curly, block… quotes.
Maybe it’s the best to enter formulas by hand, not to copy and paste.
smart quotes
blockquote is a good idea; that should prevent automatic conversion. Copy-and-paste from a blockquote should be safe — unless the paste mangles things.
Hello @Gondwana and @masterboyhr,
Thank you so much for your help! As it turns out, I had copied the code directly, which included the wrong quotation marks. I replaced them with the correct ones from my keyboard, and now everything works perfectly!
I really appreciate your guidance—it saved me a lot of time. Thanks again for pointing me in the right direction!
Best regards,
Hello. Please help me. My goal is to make the dial show the weather for 6 days. How to make the temperature show the desired minus sign - it’s winter now and the temperature should be with a minus sign, but it shows how in summer. Or am I doing everything wrong? Thanks in advance.
It’s an easy answer.
(forecastDays(1, “COND_DAY”))
does not show temperature.
It shows/returns weather conditions 0-15
  • 0: UNKNOWN_VALUE
  • 1: CLEAR
  • 2: CLOUDY
  • 3: FOG
  • 4: HEAVY_RAIN
  • 5: HEAVY_SNOW
  • 6: RAIN
  • 7: SNOW
  • 8: SUNNY
  • 9: THUNDERSTORM
  • 10: SLEET
  • 11: LIGHT_SNOW
  • 12: LIGHT_RAIN
  • 13: MIST
  • 14: PARTLY_CLOUDY
  • 15: WINDY
There is no tag for temperature tomorrow.
There are tags for min and max temperature tomorrow, use:
(forecastDays(1, “TEM_LOW”))
(forecastDays(1, “TEM_HIGH”))
OK, so when you use
and you get the result (for example): 8
it doesn’t mean it will be 8°
it means it will be SUNNY (8=SUNNY)
Thank you very much. Now I understand. “Low/High” It worked! It is a pity that so far there is no possibility in the program and it is impossible to display the “current temperature” for the week ahead.
I’m glad it helped.
When you think about it only min-max makes sense.
“current temperature” is temp at the moment, “current temperature” for tomorrow means nothing.
I mean, tomorrow when? 8 AM, noon or 7 PM, when would it be “current”?
You’re right! I probably put it wrong. I do not know what it is properly called, maybe then the “Weather Forecast” for the week))). Anyway, thank you very much again.
I also noticed that the information update is “Low/High” for a week occurs once a day after about midnight, and from exactly 00:00 to about 07:00 there is simply no information and just 0 is displayed. Of course, it really depends on the weather provider, and there’s no way to fix it.
Yes, it’s been discussed here, it’s a bug in WFS. I hope it will be solved in the future.
Also the UV tag does not work, always shows 0 on the watch.
([WTHR_TEM] > 0? ‘’: ‘’)[WTHR_TEM]°([WTHR_TEM_UNIT] == 1? ‘C’: ‘F’)
I just want to say thank you, I have learned a lot from your very useful shares. Thank you very much and wish you good health.
Hey everyone, how can I add body temperature to a watch face in Watch Face Studio? Help me in this topic :blush:
You cannot. But it would be interesting.
