I finnaly got it to show by connecting through cmd window using adb pair (IP Address) before adb connect (IP Address)
So solved? Already? Right
از وقتی که ساعت بروزرسانی شده گزینه دیباگ وایفای وجود نداره با اینکه وایفای وصل هست
چکار باید کرد؟
After the update
You need to turn Developer Options back on
got to about watch
Software version
Tap on it 5 or more times until developer Options are on
Then restart your watch
Turn on ADB debugging and ok that
scroll down to where it says WirelessDebugging tap on it
wait few minutes and
write down the IP address followed by :xxxxx the port number
Then click on Pair with new Device (apparently you have to do this ever day )
it will have a pairing code
followed by the IP port and a different port number
Run on Device
fill in the IP address in the top
Fill in the first port number when you first turned on ADB Wireless deguggin
Fill in the Pairing code
Fill in the last port number when you paired the device
You can try running on watch now
for me it says no compatible devices but that is because there is a pop up on the Watch that you have to OK and that takes longer than the search does
once that is OK’d then the device will show in the run on device dialog
the key have patience the popup take some time.
Ron
Samsung Developer Relations
