How to make time in WF show either in 12H or 24H depending on user sync from phone?
I have searched other topics here and few years ago ppl did it with “[IS_24H]” tag or timeline condition.
Problem with tags solution is when you use styles for time you would need to have everything double as you can’t mask both 12h and 24h layers together.
Is there any new way of doing this or can we set it up so its automatic?
I use the tags
AM: ![IS_AFTNOON]*100
PM: [IS_AFTNOON]*100
24HR: no tag
then you have to use the conditional timeline feature to show when they should appear
AM/PM icons for a 12 HR clock
24HR icon for 24 HR clock
Once set up you can preview by using the 12/24 buttons in the RUN panel
Ty for your reply but my question is for time itself for both 12h and 24h formats and not for AM / PM icons.
Some users prefer 12H format and some 24H^^
Yes . I think you can go with the pre-set Digital times and it will change when you Change it on your Phone in Galaxy Wearable . Or you can use the Tags for 12 / 24 hrs . Then you will have to use Tags and Time line .
That works
Just FYI for anyone that sees this, you have to have latest Beta version of WFS for hour format “Sync with device” to be available in Digital Clock component.
I had stable version and that feature isn’t available there.
you would still use the timeline for your hour1, hour2, elements and do the same thing on the timeline
