Adb probleme
hallo leute kann mir jemand helfen ich mach das genau wie beschrieben ip adresse port und kommt die ser fehler immer wieder . bluethooth ist ausgeschaltet ich komme nicht rein in die uhr. danke
C:\adb>adb pair 192.168.1.84:37125
Enter pairing code: 572165
error: protocol fault (couldn’t read status message): No error
Hello,
Please check this guide?
Follow the steps thoroughly.
If problem found, report this to developer support with Demo video, dumpstate log and device information (PC and watch).
Steps to collect log:
Make sure developer mode is on.
a) Dial *#9900#, Delete Dumstate/logcat
b) Dial *#9900#, Select Debug Level to MID. This restarts the device.
c) Reproduce the issue
d) Again dial *#9900# and press “Run Dumpstate/logcat”
e) When it is finished press “Copy To SD Card (include CP Ramdump)
f) In the main (root) directory of the device file system, please look for the directory ‘log’. That directory would contain the dumpstate log file generated, having the name format: dumpstate__
g) Compress the “log” folder and share it with us
Thanks
Shamima
Samsung Developer Program Team
