The Exynos part is indicating it has BC texture compression support, but the device only exposes BC1-BC3. We only use BC4-BC7. This is an RDNA2-based part, and we’ve been using these BC formats across many platforms for many years. We have a fallback to ETC2 and ASTC, but I was hoping to move to BC textures going forward.
This is going to confuse apps that test for BC compression support, and expect all formats are a part of that
Thank you for participating in the Samsung Developer Forum. However, this forum is for 3rd party developer issues.
Samsung’s mobile developers do not follow this board to prevent any potential dispute or misunderstanding as to the similarity between Unsolicited Submissions and our internally and independently developed products, technology and services.
I would recommend you use the Samsung Members App for feedback it has agreements for suggestions
or
go to https://www.samsung.com and depending on your location
either → Click on Explore Tab → Click on Community
or
Scroll all the way down to the bottom of the page and under support is a link to the community
Ron
Samsung Developer Community
