Body Composition Muscle Weight
Hi—
What is the difference between HealthConstants.Weight.MUSCLE_MASS (which is a % of the weight that is muscle weight) and HealthConstants.Weight.SKELETAL_MUSCLE_MASS (which is the Skeletal Muscle Weight in KG)?
The latter appears to have a more front-and-center appearance in the UI and the latter, I’m not sure where it is. Please advise.
Also, how does one record Bone Mass?
Thanks.
Eric
Thank you for participating in the Samsung Developer Forum. However, this is not the correct forum for end product bug reports, questions or concerns. This forum is for 3rd party developer issues.
I would recommend you use the Samsung Members App for feedback
or
go to https://www.samsung.com and depending on your location
either → Click on Explore Tab → Click on Community
or
Scroll all the way down to the bottom of the page and under support is a link to the community
Because end user questions disrupt developer discussion this thread will be removed soon.
Ron
Samsung Developer Community
Hi—
I’m sorry, but I do not understand your suggestion. This question is about your Samsung Health SDK and your documentation surrounding those API’s to ensure that I am using your SDK properly and that my end-users understand the data that your App shows them. I believe that this is the correct forum for that.
Eric
Thanks for clarifying this Eric. It sounded like a end user question.
I assume you have read Samsung Health SDK documentation I didn’t notice anything in that
There is a documentation here on the Body Composition App
I think the Muscle Mass is used in the BMI calculations.
Ron - Developer Relations
Not a Samsung Health support person
Hi—
Yes, I have read through your documentation and it is unclear what precisely the difference is. It would seem like the Skeletal Muscle Mass is a subset of the Muscle Mass, however, the former is the only thing that is displayed in your UI as far as I can tell. The value I am uploading is just “Muscle Mass” from the source, so I’m reluctant to map it to your more specific value. This is why I’m asking what the precise difference is in these.
Also, I do not see a way to upload Bone Mass in the API.
Please advise. Thanks.
Eric
Hi Eric,
Skeletal Muscle Mass is the voluntary muscles. I don’t know how you get bone mass. I think you are going to have to look at some Heath / Fitness or NIH site to see what each is for.
Ron
Samsung Developer Relations
