Hi! I am a developer of Android app used on a Samsung Galaxy M31s mobile phone. We are having trouble while using integration of our Android app with Samsung user interface. When I try to tap on switcher at the “Calling accounts” screen it doesn’t work correctly. At the same time, it works fine if I am tapping on the text field next to the switcher. Video of that bug is attached.
Thank you for participating in the Samsung Developer Forum. However, this is not the correct forum for end product bug reports, questions or concerns. This forum is for 3rd party developer issues using Samsung API, SDKs or other tools.
If you can’t get help from the Android community then you need to use the Samsung Members App to report bugs.
The platform developers do not view this board to prevent any dispute of originality of concept.
Ron
Samsung Developer Program
