Complication not selecting correct function
Had 2 complications for Battery and Day/Date that was working just fine. I also had a TAP for Weather and that works fine also. However now when I hit either of the complications they bring up only Weather! I’ve checked and redid each of them, reset my watch a couple times, no joy. Have a GW5. Any suggestions?
Update! I took one of the complications off and reloaded the watch and found that there is a TAP for Weather on the watch that does not show on my design. I guess the watch added it for some reason?
Any ideas here??
HI Rog,
I’ve been seeing a lot of things like this it appears that WFS Run on Device old Watch Faces stay in the Cache or something. I have got into the habit of deleting the watch face before adding one with the same name. See if that makes a difference.
Ron
Samsung Developer Relations
Yeah I get that . i dismiss all the App Pages in the Cache pressing the Lower Button on my GW4 Classic . Press it several times and it clears the problem . I think they are left there from other faces . However some need to be dismissed with the upper button and some the lower which is a bit annoying . BTW i am still working on .13
Thanks That seems to work. Difficult learning another system after getting GWS down. Such is life!
