Distributor certificate will not create
I created one. Distributor Certificates are only one on one between a specific watch and specific computer. When you upload to the store they are replaced with Samsung Distributor certificate for testing and distribution.
So you have to have one to build to create the binary. And that is the issue. It may be since I have no issues the US seller portal has a US certification URL and the rest of the world has Korean and that is why I am able to do it and others aren’t .
Ron
Samsung Developer Program
Thanks very much was pilling hair out trying to figure it out
@r.liechty_SDR
I still can’t.
Is this problem solved?
this has been going on for a long time. I have been unable to create a certificate for 7 days.
Hi Ron,
I was finaly able to create new distributor certificate and build my new watch faces. But now I have a problem with one of my old ones.
I tried more but only this one has a problem. Do I have to rebuild it from scratch?
Resources not found are generally a missing or corrupted file (image or font file).
Some times this is an issue with the AOD so check that to see if it lists a file that isn’t there.
If that isn’t the issue make a copy of your .gwd project file rename your .GWD project to .zip you can open the project and inspect it. Usually you can figure out what is corrupted or missing.
Ron
Hi Ron,
thank you for your help. It was one small image that was not suppous to be in the design, I removed it and now it is ok. So thank you again :slight_smile:
