I am having a Struggle understanding what I have to do to send a Face from Galaxy Watch Studio to my Galaxy Active . I have done it many times in the past , But not for a while . Sadly I am at a stage in my Life where I am not getting more clever . Is there a simple fix for this Certificate thing . I can not make Head or tail of the Topics already on the subject . I Have made a bit of a mess with the password as I have Got a new one for my Samsung Account . Is it an Issue these days because I am working on WFS ? I do not have to Build the faces there .
To add I have also recently gone over to WIN 11 .
Hello russellcresser,
Sorry for the inconvenience.
One possible workaround of this issue is creating a new distributor certificate. However,
since Aug 22nd 2023 IE browsers are not supported on the Seller Portal. GWS uses an internal browser that is based on IE and you can’t log in to create the Distributor Certificate if your computer is updated or if you have to pair your watch to a new phone or reset it.
Currently there is no plan to release new version of GWS. As a workaround you can check out this thread in Samsung Developer Forum. Ron has discussed this topic here. Following post is marked as solved so you can check this out.
Thank you.
@Jakia.Sultana . Thank you so very much . I am Basicaly a Hobby Maker .
I am extremely fortunate to have a Partner that has published a few of my WFS Faces . However I belive that has become virtually Impossible now . I am too Old Now to embrace what feels to me like a major IT Chaillange . My Active will have to stay as it is for now .
However if I suddenly start too feel compotent enough, I have the Instructions to Load my old Faces on my old Active . Thank you very much Indeed .
