Every component in my project is invisible after reopening it.
After making some changes, I closed the WFS and it asked me if I want to save the project? I clicked OK and when I reopened it was all invisible. What should I do?
Restart pc and open WFS again they will be there.
No, it didn’t. Its been a couple of days now. I don’t think I can recover it!
If that so then you need to redo all the work.
What version of WFS are you using? Is it the very latest 1.2.6.
If you can upload the .wfs file to tech support they may be able to see what the issue is. If the resources were gone you should see a missing resources error.
Ron
Samsung Developer Relations
I have noticed the latest 1.2.6 has tendency to corrupt project file while adding new component or saving project files. It happened two times so far. Luckily I was able to recover the project file from OneDrive history. I recommend do Save As instead of Save when working on the project.
I am on the latest version 1.2.6. I’ll try contacting tech support.
Can I ask one more thing… Is it possible to detect if the if the watch has entered AOD mode?
It hasn’t occurred again. I started backing up my project after each iteration.
of course it is or they wouldn’t know when to show the AOD face. But I know what you mean is it possible with WFS and sorry there is no tag on this.
Ron
