Same Problem here, I did not have to do any of that this is all I did .you have to Reboot the watch ,put your watch on the charger, Turn on WIFI, Auto is fine, Then goto settings > Network
and connect to into your network make sure you check that its connected to your system network, get the ip address of the watch.
Run studio I would close it and reboot.
Anyway Bring up run on device, Scan or ip address.
if done this way you should get a notice as to debug or not.
I did everything that was advised to me, but it did not bring the expected result.
I reset default settings. After loading, I repeated all the steps from the very beginning. This also did not bring the expected result. WFS still can’t see my watch.
Is the watch on the charger? If its not on the charger WIFI will disconnect. you must then go to setting network and click your router you have to do this to get the ip address.
Yes, WI FI is on.
When I launch SDK Tools from the command line and enter the “adb connect 192.168.31.203:5555” command, the “Allow Debugging” popup appears - I say “OK”.
And even after that, I don’t see galaxy watch4 in the device list
That is what you want to happened, But you need to use watch face studio to do the same thing . If you use SDK first , it will connect to your watch, so watch face studio will never see it. So do not use SDK.
UPD: I have another laptop. I installed WFS on it and it connects to my chats without any problems.
There might be a problem with my computer, but I don’t know how to solve it.
The “problem” with your computer that’s its connected ‘with cable’ instead of ‘wifi’ if the computer is connected with cable face studio will never find your watch
