How to connect cloud phone to debug with Android Studio?
How to connect cloud phone to debug with Android Studio? Thank you for answering.
Use the Runtime Test Lab If you are having an issue with it either be more direct here or contact the RTL team from that page
Ron
Samsung Developer Program
Thank for your answer!
In my opinion, you will have to connect your device to your development machine with a USB cable. If you developed on Windows, you might need to install the appropriate USB driver for your device. Then you will have to enable USB debugging in the Developer options window. In Android Studio, select your app from the run/debug configurations drop-down menu in the toolbar. I believe there are several companies that provide Enterprise Application Development Services that can get this done efficiently and cost-effectively.
