How to Connect Watch Face Studio with Galaxy Watches Running Wear OS?
Are you a Watch face designer and facing issues to connect your WFS with your Galaxy Watches running Wear OS?
Then, this tutorial is for you. It describes the detail about how to connect the Galaxy Watch running wear OS to WFS over Wi-Fi and run the project. You will also learn the connection process via Wi-Fi through the ADB shell command.
Thanks,
Shamima Nasrin
Samsung Developer Program Team
Finally a blog on this. Compare to my guide its much better.
More blog like this should be created
This post was flagged by the community and is temporarily hidden.
quick question, do i need to disable the blue tooth connection between my watch and my phone before i get started? or is that just disabling the debug through blue tooth?
i’ve had few issues connecting my watch to wfs but it does sometimes get a bit wonky where it’ll disconnect in the middle of running or disconnect once it’s finished.
Hi, just disabled bluetooth connection or put watch on charger.
@Knightwing
thanks. i knew putting the watch on the charger helped. i did not know i had to disable the bluetooth though.
Hi either or will do. Btw
Thank You so much for post the how to on connecting my new galaxy 6 classic watch. It’s been driving crazy trying to connect it.
