How to Fixed Battery Drain on Weather Watchface?
Hello everyone,
How to fix battery drain on weather watchface made on GWS? I have so many bad reviews because of that.
Thank you!
You might want to follow this thread How to Fix Battery Drain on Weather Watchface? A similar discussion is going on there.
but to recap
Do not have GPS on
Do not have WiFi always on
Do not use Weather in AOD mode
Do not have frequent weather updates once every 3 hours is standard
If you have an older watch it has less battery life so it may show more drain as a percent than the newer watches show.
If you are using images for weather tone down the opacity.
Ron
Samsung Developer Program
I have the exact same problem. Have tried a variety of things!
