Hi I’m Newbie of GWS
I wonder How to Sync Battery Percent with aod second hand
If you know to how to sync it help newbie
I’ll really appreciate it Thank u
Watch your health from covid-19
AOD doesn’t have a seconds hand, or ability to show seconds on the AOD. Maybe the translation isn’t that good?
Hello,
I am not sure what you try to make, but if you want to make the second hand to show battery %, then simply insert it in design as you would any other hand. It by default syncs the hand with hours. Then
Did not know that would work on AOD second hand…
It will just look like second hand, but it will be showing battery percentage during AoD
Thanks for your kindness
I got function of ‘aod’ and i made it by your comment
basically second hand
aod func battery percent hand
Thank you So much
Have a nice day
I really appreciate it
