Hi
I can make logs from Galaxy Active 2, for example. Just put code *#9900# on Gear Dialer ( Phone app)
But how it could be done on Gear Fit 2 Pro?
My buyer ( not all users) has error when he try install my app for Gear Fit 2 Pro.
Gear Fit 2 Pro doesn’t have Gear Dialer ( Phone app) and it’s seems something the similar
I do not have now Gear Fit 2 Pro
May be somebody with Gear Fit 2 Pro now can help with this issue?
P.S.
The issue has been resolved.
If someone needs, then here’s how to send logs on Gear Fit 2 Pro:
[How to extract Fit2 logs]
- In the Fit2, Settings -> Gear info -> About device > 5 times touch the “Software version”(Binary information) > Expose the Key string
- Input #9900# on Key string > Expose the menu of “LOG Dump”
- After running “Run LOG_DUMP”, when the log creation message appears, select Ok and then select the send “LOG_DUMP”.
- In the Mobile device, Phone > Pictures > Gear
You can get the log in the form of a .tar.gz file.
