Missing resources when building
I can’t run on device or build. It doesn’t work with anything I created myself, or just when loading samples. I have re-installed versions 2.1 and 2.0 to see if there is a difference, but versions 2.0 doesn’t’ even give an error message, the program just crashes. I get a message saying “Build error! Resource are not found, please check that the resource is available with your gwd project” and then this
A: This is an error on GWS 2.0.1 because it doesn’t build the AoD. It also is an error if you select Tizen 5.5 as a build option. Unless you need it for some special reason never use GWS 2.0.1 you will get unexpected errors and several people have reported it corrupted their Author Certificates.
Uninstall GWS 2.0.1 restart your computer to get rid of any cache install GWS 2.0.0
If you are a seller back up your author.p12 file if you aren’t a seller it doesn’t matter.
Create new certificates both Author and Distributor certificates
You should be able to open a project created with GWS 2.0.1 with GWS 2.0.0 and any AoD you created will be restored. But check the AoD to be sure.
If you still get the build issue there may be some other reason. I’ll have you generate a log.
Ron
Samsung Developer Relations
Thanks you for your answer. Initially, the GWS 2.0.0 version kept crashing when trying to build, but after reading the log I found out it was a Java error and I managed to fix it by reading this and installing the correct Java version: https://developer.samsung.com/galaxy-watch-tizen/studio/tutorial/compatibility.html#Required-Java-Versions
@eliyetres
It shouldn’t let you install if you have the wrong Java version so I would never have thought of that.
Glad you got it working.
Ron
