I’m trying to build my watch face and launch it on my Watch Active 2, but I got this warning and error and the build fails.
Build Info:
What I got:
What should I do?
Build Info:
What I got:
What should I do?
I am going to bet you are using GWS 2.0.1 and the resource missing is the AOD.
If you are not on Mac go back to Previous Version GWS 2.0.0 and you can just use the same project and all will build and install correctly.
Ron
Samsung Developer Relations
I have the same problem except that solution didn’t work.
What version of GWS are you using? as I said this happens with GWS 2.0.1 it is better to go to Previous Versions and reinstall the GWS 2.0.0 version
If you are using GWS 2.0.0 be sure to build an AOD it is necessary.
Let me know if that isn’t the issue.
Ron
