.net Debugging Variable types issue
I am using Visual Studio 2019 to develop a.net native application for Samsung Gear S3. I have modified the XStopWatch example. During the debugging process the debugger is displaying incorrect values and variable types. I am using the wearable-4.0-circle-x86 emulator with the following packages
nuget\packages\tizen.net\8.0.0.15631
nuget\packages\tizen.wearable.circularui\1.5.0
nuget\packages\tizenhotreloader_4\1.0.0
I have recreated the problem from the basic wearable template app.
When debugging this code (setting watches) the variable types and values listed are incorrectly
1: i = “Alert: Alert Name 2” ( clearly defined as an int)
2: a | a: error: use of undeclared identifier ‘a’ error: 1 errors parsing expression|| (defined as MyAlert)
I have recreated this in a windows console application and everything works properly
Code
public MainPage()
        MyAlert a1 = new MyAlert("Alert Name 1");
        MyAlert a2 = new MyAlert("Alert Name 2");
        List<MyAlert> alertList = new List<MyAlert>();
        alertList.Add(a1);
        alertList.Add(a2);
        int i = 0;
        foreach (MyAlert a in alertList)
            string alert = a.ToString();
            Console.WriteLine(alert);
        for (i = 0; i < alertList.Count; i++)
            string alert = alertList[i].ToString();
        InitializeComponent();
public class MyAlert
public string Name { get; set; }
    public MyAlert(string n)
        Name = n;
    public override string ToString()
        //return base.ToString();
        return "Alert: " + Name;
Seems like this might be an issue with your Visual Studio IDE.
You can try to reinstall the IDE on your PC or if the problem still persists, you might be able to find better support at Visual Studio’s Developer Community.
