The BLE (Low Energy Bluetooth) connection between a glucose sensor and an app on Samsung Galaxy Watch4 functions reasonable well when I sit, but during a walk or when cycling the watch app doesn’t receive glucose values anymore from the sensor. After standing still for a few minutes the watch receives glucose values again.
When a smartphone is connected to the sensor, it doesn’t have these problems.
I didn’t try out any other smartwatch, so I don’t know if it applies to WearOS in general.
The sensor used is a European FreeStyle Libre 2 Sensor.
The WearOS and Android Smartphone app used, Juggluco.
The following didn’t help: turning off activity detection, turning off Wi-Fi, uninstalling everything mentioned in: https://forum.xda-developers.com/t/debloat-galaxy-watch-4.4324147/ (including Samsung health) and turning off Mobile battery saver in developer options.
I see in the Juggluco app description that it was updated just 4 days ago. There were Updated/new Wear OS libraries and that might be the reason. I suggest you contact the app developer on this.
If you are developing then I’d need more information on what your issue is.
If you have problems with an app, you should naturally contact the developer, but I believe that doesn’t apply to me.
During physical activity there are constant Bluetooth connection problems.
The BluetoothGattCallback onConnectionStateChange(BluetoothGatt bluetoothGatt, int status, int newState) is constantly called with newState == BluetoothProfile.STATE_DISCONNECTED and status=133. No function from an app supplied shared library is used before that point.
I am the developer, why should I contact myself.
The app also doesn’t detect physical activity.
I see only two possibilities:
• Bluetooth connection is physically worse during movement;
• Something on the watch is programmed to behave differently during physical activity.
I wasn’t sure if the question was from a developer or someone using the app.
Unfortunately neither of those is relevant to this forum and I have no idea where you can address them unless there is an Android Wear OS discussion group. If you could say this is only on Samsung smart watches or all smart watches with Wear OS Powered By Samsung maybe I could find a way to report it.
