I need to create Tizen Wearable .NET Application.
For development environment I am following below link .
https://docs.tizen.org/application/vstools-mac/overview/
Visual Studio for Mac extension for Tizen is missing in my IDE.
- Can you please let me know the reason for extension not available.
- Is there any other setup to follow on Mac.
Mac OS Big Sur
Version : 11.2.3
Visual Studio for Mac(Community)
Version: 8.9.3(build 13)
The Prerequisites are macOS Catalina and Java JDK .
macOS Big Sur does not support Java JDK
There may be a better solution other than run Windows in your macOS Big Sur.
Ron
Samsung Developer Program
Should I try to setup, with Visual Studio Code as mentioned in below link.
Will this work.
[edit: broken auto-link to https://docs.tizen.org/application/vscode-ext/dotnet/#setting-baseline-config has been removed. Try Installing Visual Studio Code Extension For Tizen | Tizen Docs]
