I tried installing the VSCode extension, but it looks like it depends on a package ms-vscode.csharp which has been renamed by Microsoft to ms-dotnettools.csharp so it no longer works.
There is even a message from Microsoft on the Q&A to the extension mentioning this transition but there hasn’t been an update on the Tizen extension since 2019.
Same problem here. Since Version 16.7.2 Tizen Extension shows me Android Devices too, and it is no longer possible to install/debug from VS. After 15-18% it stops the install process
Every time i open my solution file (with 40 tizen projects), i ran into a lot of error messages, that tells me, the visual studio has an “unexpected” (what else…) problem with the tizen projects. It is definitively not a problem of VS.
Samsung doesn’t seem interested in attracting .NET developers …
In the developer support channel, Samsung provides technical supports for Samsung SDK and tools to the developers. As it is a development tool related problem, I hope this will help you.
Hello,
There is a workaround to bypass the issue. You will find the solution here and to make it easy I am going to write down it bellow.
You need to modify some files and everything will work fine.
In windows pc go to C:\Users\user_name\.vscode\extensions\tizen.vscode-tizen-csharp-1.2.0 then in this folder edit the file name .vsixmanifest.
In this file, you will find Property Id=“Microsoft.VisualStudio.Code.ExtensionDependencies” Value=“ms-vscode.csharp” this line. Now change the value as Value="ms-dotnettools.csharp"
Now go to package.json file in the same directory and change the following line “extensionDependencies”: [“ms-vscode.csharp”] with “extensionDependencies”: [“ms-dotnettools.csharp”]
I think this will solve your problem before the update.
