Not Getting what I design
Ok , will check the wfs, thought u said u figured it out?
@davihealthticwatch try this editied file.
Test.zip (179.3 KB)
If this works compare the different in my wfs to yours
No difference from what I I posted the first time.
Using my? Wfs? Seem watch complication issue…
You might have to redo according to my method…sometimes the wfs when push to the watch uses your older version…you may need to uninstall the face and do run on device again. Not just overwrite it.
One way to be sure u using the correct face is change the color of the clock to another color if still red then its loading the wrong face.
Regarding Font Size and color.
The SMALL TEXT BOX is where the “RANGED VALUE” will display.
It doesn’t matter what is interred in the field.
The TEXT APPEARANCE VALUE must be set to a very large number…
This is what I see on the watch.
Or what I did. Changed the file name.
@davihealthticwatch changing the file name sometimes wont replace the face also its caching
Hi, dont understand…why u need sure large number?
It becomes smaller? On the watch?
Maybe do by trail and error… adjust/compensate accordingly, so e.g try moving the icon further away from X, and change fount by multiples
E.g for 10px try 10,20,30 etc to work around the incompatibility
All I know is that when I put 200 in the field I circled in ORANGE, I got the size you see on the picture of the watch.
I spent some time changing that number and also changing fonts and colors and moving the TEXT box arround and the ICON around and changing the ICON color and it work.
TITLE BOX will put what you fill in the field on the screen in the size and color you select.
Progress bar doesn’t seem to connect to the RANGED value.
I need a large text on the watch so I can see it without my glasses.
I know its troublesome. But what to do if its a really a issue of incompatibility , either experiment or report as a bug to revelent companies.
I have started deleting the face from the watch between each RUN ON DEVICE try.
I am not sure but seem there should be a change…with my wfs. As i force it to use the layout of choice meaning only range value
Try just in case change to green text…if still red then wrong else it my wrong diagnoses
Just trying to eliminate all doubts…as this is how i troubleshoot things
I think, with what I know now, I can make a TEXT ONLY face that will do what I want to d for when I am in bed.
I need to complete it and run it for a few days to make sure the BO2 is updating with every new reading in accordance with the settings I have in the watch.
I have my SLEEP TIME set so the watch thinks I will be asleep between noon one day to 11 am the next.
When I am sleeping I can have the watch do real time monitoring so essentially, it gets a BO2 reading every time my body is still enough for the sensor to work.
When I am actually asleep, therefore not moving very much, it gets a reading about every 2 minutes.
When it doesn’t think I am asleep because I am moving, it tries for a reading every 5 minutes.
Here is a record from a day I wore the watch the whole day.
Good enough?
Hi watch issue, i guess thanks for confirming it
My circle something is there…could it be croped information?
It would not surprise me that Mobvoi has done some mucking around in the WEAR OS code or put some extra stuff other ways.
They have also released their own EDITOR call TIMESHOW but to make much use of it, I would have to pay a monthly subscription.
$19.95/mo.
NOPE, Not going to pay that much to make one watchface.
Could be? Is to make u pay for there tools? Who knows
