The phone complication is corrupted since a while ago.
the phone charger % is sitting on my watch 6 at 74%.
no changes since a while ago…
it was working fine on all watch faces I created. but now is not!
I even changed the Watch Face Studio with a new install 1.7.9 and 1.7.13. still the test failed to make the phone complication working.
where is the problem? and it stopped working?
Thank you.
Do you have multiple complication options?
If so could one of the other options, without the correct display setting be showing by default?
I was testing one complication ONLY. Phone complication… and it’s not working.
The reason is, IDK!
And all the original Watch 6 all the watch faces phone complication get stuck at 74%. ONLY.
AND won’t move anymore on each Watch face I created.
And this is the ONLY complication doesn’t work for now even after updating the watch 6 for the last update this morning.!
Thank you.
I have not experienced any issues with the 2 phone complications that I use.
My go to is from @amoledwatchfaces
This is the one I test on all my faces
The second is from a Complication set that specifically targets Diabetics. (GlucoDataHandler)
I know with the recent Wear OS 5 on the Ultra that I had to grant it was permissions or alarms II forget which .
I had to uninstall the phone complication from my watch. and install it back from Google store… and now it’s working…
Must be a glitch from the updates has been done by Samsung or Google!. I don’t know.
Thanks anyways
